Re: Farmall Regular Yr???
Posted by russ hamm on November 25, 2006 at 14:06:34 from (63.245.179.200):
In Reply to: Farmall Regular Yr??? posted by massey 44 on November 25, 2006 at 10:53:09:
massey, that would be a 1929 model. check the serial number section on this site and you will see. yes, an f-20 mag will work, although you may have to change the coupler flange to accept the f-4 mag. if it had an e-4a mag the flange is for a smaller coupler. it can be changed though as the blocks and all are the same. you will have an automatic impulse with the f-4. original e-4a's are available if you want to keep it original. good luck. russ
