Re: H, axle bolts are STUCK! air impact?
Posted by Haas on November 25, 2006 at 18:18:50 from (12.65.42.186):
In Reply to: H, axle bolts are STUCK! air impact? posted by arod on November 25, 2006 at 11:09:02:
As others said, get a 3/4 inch drive socket and breaker bar with cheater and make sure the socket is a six point. Then use the breaker bar and plenty of penetrant. Let is soak for a day or two. Also, forget the 1/2 inch drive impact. If you did not get it with the 1/2 inch breaker bar, you certainly won't get there with the 1/2 inch impact wrench.
