Re: H, axle bolts are STUCK! air impact?
Posted by IBorange in TX on November 25, 2006 at 20:03:06 from (72.251.14.105):
In Reply to: H, axle bolts are STUCK! air impact? posted by arod on November 25, 2006 at 11:09:02:
I would soak them with PB, etc,for a couple of days. Use a 3/4 round soft rod and a 3#hammer. Place the end of the rod on a face of the bolt and give it a good good slam w/the hammer. By doing so, you will warm up the bolt enuf for the liquid to penatrate deeper. Then use the socket set. It will loosen the bolts. BTDT.
Good Luck.......
