Re: Cub won't start after rebuild
Posted by El Toro on November 26, 2006 at 13:02:53 from (64.12.116.65):
In Reply to: Cub won't start after rebuild posted by Kermit on November 26, 2006 at 09:37:43:
If you pulled the mag off during this rebuild you may be timed on the wrong stroke. Pull No1 plug near the radiator and bring No1 piston to TDC on the compression stroke. Once you have it at TDC
pull the cap on the mag and see where the rotor is pointing. Should be at the No1 plug tower.
Squirt some gas into the plug hole and see if the engine tries to run. Like the Magman says keep an eye on that oil pressure. Post back if there's no pressure and don't keep running the engine. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
