rim clamps reversed on 400
Posted by SDE on November 27, 2006 at 03:43:01 from (207.118.218.22):
To remove the tires and rims from the tractor,I had to remove the wheel. The square head bolt went thru the wheel and clamp from the outside. A nut was on the inside, under the inside clamp. After removing the nuts that held the inside clamps, the tire would slide in toward the axle housing, instead of away from tractor. The only thing I can think of is, that at sometime in this tractors past, it had duals on it. If these wheels were reversed, then the rims could have been removed to outside, without removing the wheel. Any other explainations for someone to do this??? Previous owner had a cornpicker on it.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
