Re: Duals again
Posted by Hugh MacKay again 2nd on November 27, 2006 at 05:12:23 from (209.226.247.97):
In Reply to: Duals again posted by Wardner on November 25, 2006 at 18:10:48:
Wardner: Another idea I looked at 35 years ago was 656, and having duals spaced for corn planting 30" rows using a second set of cast wheels. Farmall 656 has same wheel as SM, 400, etc. Axles were not long enough to give spacing I wanted. I never did do this, by the way. My idea was to get an axle stub about 12" long, clamp it in outside wheel, weld a snug sleeve to it that could slide over tractor axle. Then I was going to find a heavy wall pipe same inside diameter as outer circumference of wheel weight mounting holes. I then planned on putting long bolts through both inside and outside wheel. I expect you could do the same with that 660, with the exception of the axle shaft coupler. I figured the axle coupler would make it stronger, should outside wheel take all the weight. With regards to snap on duals. I have seen the snap on duals wear the inside rim if they weren't held tight together. I expect that being loose is how folks broke cast with snap on duals. Loose wheel can be awfully hard on cast hubs, as some of us learned in our younger years.
Home
| Forums
Today's Featured Article -
Check Your Coolant - by Bill Radford. Great tips on how and when to check the coolant in your tractor.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
