Re: Farmall H broken rear wheel
Posted by D Slater on November 27, 2006 at 14:16:15 from (152.163.100.65):
In Reply to: Farmall H broken rear wheel posted by Trouble in Va on November 27, 2006 at 11:37:56:
Not sure what was used to cut new keyway in a wheel like yours, but have saw some with a good job and using a key like was used in 350 and late 300 farmall wheel with 2 1/2 inch rear axle. Key fits in wheel and axle both. This is from someone that lives in a former part of your state. Lots of trouble here also since the war between the states.
