Re: 1066 International
Posted by Hugh MacKay on November 27, 2006 at 16:26:08 from (209.226.106.24):
In Reply to: Re: 1066 International posted by Steve From Arkansas on November 24, 2006 at 15:28:46:
Steve: Poor front end in my opinion for that large of tractor, and mine never had a front end loader. It did have dual wheels and twice front end dropped in holes, and we recovered the front wheel and bottom half of spindle under the rear wheels and once under cultivator behind tractor.
It should have either had a straight axle with king pins like a truck or 4 wheel drive. Either case minimum front tire should have been 14x24. The 1066 front end is really very little heavier the 656 or 560, and I'll bet the front end weight of a 1066 without loader is double that of either the other two.
