Re: 660 ground speed
Posted by D Slater on November 28, 2006 at 09:19:16 from (64.12.116.65):
In Reply to: Re: 660 ground speed posted by steelfronts on November 28, 2006 at 04:33:32:
If tractor has the low speed 1,3 and 4th gear in transmission plus planetary gears and maybe smaller diameter tires. I would think it would be slower than some even with the increased RPM they were set to. On the T/A if the T/A clutch does'nt slip you have dirrect drive. If T/A works on low side it does'nt care if T/A clutch is even there as long as its released.
