Re: Let's talk about an electrical overhaul
Posted by John T on November 28, 2006 at 14:53:07 from (66.244.90.5):
In Reply to: Let's talk about an electrical overhaul posted by Mike CA on November 28, 2006 at 08:31:17:
Mike, its your tractor and only you can make the call. That being said, theres no reason why an H wont start at the original 6 volts if a good heavy battery and 00 gauge Battery n Starter n Ground cables are used so why not keep her original and standard????
YES you can get an exact and same sized genny for 6 or 12 volts NO PROBLEM, either get a new or used or rebuilt (or even have old 6 volter upgraded to a 12) genny and a Voltage Regulator to match what voltage you choose, piece of cake.
You can still use the original 6 volt starter regardless what voltage you choose.
The light bulbs have to be 6 or 12 volt depending on what you choose.
If you go 12 volts you can EITHER use a 6 volt coil but add a series external voltage dropping (12 to 6) ballast resistor or else get a full true 12 votl rated coil, no ballast needed. Of course if you stay at 6 volt use a 6 volt coil. I see no reason to convert an H myself, why go the expense of making her look original when original itself is fine??? so pay your money and make your choices.
best wishes
John T
