Re: Super A seal leak
Posted by banjo on November 28, 2006 at 20:55:20 from (65.67.203.166):
In Reply to: Super A seal leak posted by SuperA-Tx on November 28, 2006 at 20:28:10:
If you are getting oil above the seed plate drive opposite of where the brake rod goes in , it is either # 9 in the picture or it is the transmission bearing cage seal or the bearing cage 0 ring not shown it that picture.
other seals in the picture are # 26,27,37 unless i missed some scrolling up,down,back and around. picture is either too small or too large.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
