Re: H Fizzle update
Posted by tn terry t on November 29, 2006 at 03:48:51 from (64.12.116.65):
In Reply to: H Fizzle update posted by Tom Windsor on November 28, 2006 at 20:46:23:
that trans fluid is going to seep by the rings regardless if it had a new rebuild it still will seep by . what i would do is get her fired up and and tie her to something heavy and work the crap out of it sometimes the rings will stick. more than once i hace stoped an old engine fromsmoking and excessive blowby
