Farmall Tractors Discussion Board
Re: Re: Steering on IH 184 LoBoy
Posted by Mike on February 01, 2000 at 09:20:55 from (206.159.164.17):
In Reply to: Re: Steering on IH 184 LoBoy posted by Jim on May 17, 1999 at 07:09:21:
I have both a 184&154 and have a few suggestions. Most likly you hit something and bent the drag link rod (longest one).Check your spindles when you turn full left/right you should be hitting the stops that are cast into the axle,if not then you have many places you can make adjustments.Also make sure the drag rod is not hitting the clutch cover(it`s close)you may have to relocate the steering arm on the str. box spline to get it right. Good luck,Mike
Post A Followup
: Re: Re: Re: Steering on IH 184 LoBoy
