Farmall or International
Posted by Roger Mills on November 29, 2006 at 14:55:07 from (64.122.113.206):
A while back I posted a msg that someone had donated a Farmall A. It showed up yesterday late. I got a first good look today and am now confused. The upper left corner of the ID plate has a data block with "I A" stamped on it and to the right of that is the block that would have the model and serial number. In this case it has "I A A 22xxxxx". I do not know if it is 22xx, 22,xxx or 22x,xxx. Have to get the paint off. The question is what are the I A and I A A designation. An industrial should be A I and not I A or so I thought. Is this an International instead of a Farmall?? The engine number is crudded up and painted over so it will have to wait until I can clean it up a bit.
Just for info, the air lift is complete and connected to a lift frame pivot bar with two lift arms in the back and it has a cable connected to a third arm that goes down around a pully block then forward through two more and lifts a front dozer blade at the same time. On the right is a cog latch handle that will latch the dozer at any of 8 different heights. Not a wellded up lift, all bolts are in place and the frames bolt dirctly to the tractor in normal places.
Motor turns very stiff but all the way around. It has early A ammeter and oil pressure gauge, the shutter is there but busted temp gauge. All eight weights are installed. Has adjustable front axle but non adjustable front rims. Small dents in grille but the tin is in excellent condition. Has kerosene system but line is missing and tank is rotted out. The manifold cover is missing and the flapper is rusted in the cold position. Has mag and Bosch generator and starter boss has cover plate with only one front light and no wiring for other lights.
I was told that it ran and worked 6 or 7 months ago and has been inside since than. I will see if there is any spark and try some gas in it in a couple of days.
There is no belt pully so I am totally bummed out, ha ha. Not a bad freebie.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
