Re: MTA- 12V or 6V??
Posted by Rustyfarmall on November 30, 2006 at 08:13:05 from (207.32.13.228):
In Reply to: MTA- 12V or 6V?? posted by RookieFarmer on November 30, 2006 at 07:43:57:
The tractor would originally have been a six volt, positive ground set-up. If the tractor is equipped with a generator, it is most likely still a six volt, but is possible to have a 12 volt generator, which is most likely to be a negative ground. If the tractor is equipped with an alternator, the chances are about 99.9% percent that it is a 12 volt negative ground. Another thing, if the battery you took out had 3 caps on it, it was a six volt. 12 volt batteries will have 6 caps. Now, one good thing about these old tractors, the starter really doesn't care if it is hooked up to 6 volts or 12 volts, and it does not care if it is positive ground or negative, although cranking the engine over for long periods of time with 12 volts could cause damage to the starter.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
