Re: GVW of IHC 560 Standard
Posted by Wardner on November 30, 2006 at 08:24:43 from (206.148.20.36):
In Reply to: Re: GVW of IHC 560 Standard posted by billde on November 30, 2006 at 06:36:19:
Nebraksa didn't test the IH 560. The Farmall 560 weighed 6785. The IH 660 weighed 9635. One of the 660s was tested at 15,075 by adding ballast. I have been told the planetary adaptation added 1500 lbs to the 660 and there is little other difference between the two tractors from the tub forward. 9635 minus 1500 lbs would be 8135.
Loaders can vary significantly in weight depending on their ruggedness. I would assume the IH 560 had a beefy loader.
560 and 660 did not have interchangable wheels. 660 wheels will not fit on a 560. The 560 had three wheel options. Disc, light cast, and heavy cast.
