Re: Any mag tuneup advise before I start?
Posted by Bob on November 30, 2006 at 08:31:31 from (69.178.229.154):
In Reply to: Any mag tuneup advise before I start? posted by unioncreek on November 30, 2006 at 08:13:10:
Remove the 3 screws holding the complete rotor drive to the mag, and remove it as a unit. Don't take the 2 screws out the hold the cover over the gears, UNDER the distributor cap, or you'll be messing with timing marks. (Of course, cleaning up the gear, and putting new grease in there is a GREAT idea.)
Here's a link to the oficial IH Blue Ribbon Mag Service Manual:
http://www.cleancomputes.com/Cub/Blue%20Ribbon%20Service%20Manuals/GSS-5035%20Service%20Manual%20Magnetos/index.html
