Re: MTA- 12V or 6V??
Posted by John T on November 30, 2006 at 09:56:30 from (66.244.90.5):
In Reply to: MTA- 12V or 6V?? posted by RookieFarmer on November 30, 2006 at 07:43:57:
Rookie, All I can do sittin here not looking at your tractor is provide some clues as to how its currently configured. Since many got changed polarity and/or voltage over the years REGARDLESS how they were originally, I will proceed as we dont know what it was before........
1) You might take a look at the coil for any 6 or 12 volt labels??? If its clearly labeled 6 volts AND If THERE IS NOT any external series ballast resistor wired before it and after the ignition switch (if its not a Magneto equipped ignition) it was probably a 6 volt tractor. HOWEVER if it has an external ballast resistor ahead of the coil ORRRRRRRRR if it has a full 12 volt coil, it was probably at 12 volts. If theres no labels, a 6 volt coil primary would be around 1.25 to 1.75 ohms or so, while if its a 12 volt coil it would be more like 3 ohms. The primary is measured between the coils lil + and -terminals.
2) This is hard to describe over the net (if there I may be able to tell you) but if you apply 12 volts to the starter and she cranks reallyyyyyyyyyy fast, it was probably a 6 volt system. The starter still turns the same direction regardless of battery polarity. If its a 12 volt starter and you apply 6 volts, it would crank reallyyyyyyyyyyy slowwwwwwwwwww.
3) If it has any working lights and 6 volts were applied (or if you can read any labeling on the bulbs) they would glow normal brightness but 12 volts would make them burn reallyyyyyyyy bright just a second then they would burn out. 6 volts on 12 volt lights would make them glow reallyyyyyyyyyy dim.
Tell you what, Im ordinarily NOT a fan of voltage conversions on smaller tractors like an H or C or B etc buttttttttt on an M Id be tempted to go ahead n make her 12 volts now since you gotta buy a new battery anwyay. If you wanna keep her at 6 volts, however, thats still not any problem ESPECIALY if you discover it already has 6 volt coil and lights.
If you stay at 6 volts and use a regular generator (maybe one on it is fine???) Id go with Positive ground (be sure n polarize the genny before you start her),,,,,,,,,,,,,,If you wanna go 12 volts or especially if you go the alternator route, then Id go negative ground.
Post back any question
best wishes
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
