Re: Any mag tuneup advise before I start?
Posted by El Toro on November 30, 2006 at 10:19:55 from (64.12.116.65):
In Reply to: Any mag tuneup advise before I start? posted by unioncreek on November 30, 2006 at 08:13:10:
I would check the magnetism in your magnets to make sure they are still strong. Pull the coil cover and touch them with a flatblade screwdriver.
Should attract that screwdriver with some effort.
This is what creates the spark when they pass by the coil. If you are installing new points, I would take a cotton swab dipped in alcohol and clean them. Your old points, if they're not pitted they may just need to cleaned with a piece of 320 grit wet or dry and use the alcohol on them too. Hal
