Re: Farmall C Hydraulic's
Posted by Nat 2 on November 30, 2006 at 11:11:29 from (64.80.108.52):
In Reply to: Farmall C Hydraulic's posted by Joe Costello on November 30, 2006 at 09:41:54:
As stated below, you need a BYPASS BLOCK to bolt between the hydraulic lines and the touch control block under the gas tank.
You can't braize a Tee into each line because hydraulic oil follows the path of least resistance like electricity. There would be no way to get pressure to the loader because the fluid would just go through the other side of the tee and back into the touch control unit.
This is why you need a bypass block. The block sits in between the pump and the touch control unit and bypasses the oil so that you can redirect it to one or more hydraulic remote valves.
