Re: O/T Model A Axle
Posted by Wardner on November 30, 2006 at 18:43:39 from (206.148.20.13):
In Reply to: Re: O/T Model A Axle posted by Leroy on November 30, 2006 at 17:48:55:
I have a '32 Ford and those are not the same hubs and brakes although the bolt pattern is. '32s used 18" wire wheels and a cast drum/hub. '33 used 17" and I think '34 used 16" wire wheels. Anyway, all those tires are available thru places like Coker Tire. The 'B' and 'C' four cylinder Fords used the same tires as the V8. There was a brief period in the '30s ('37 and '38 ?) where Ford got away from the 5.5" (?) bolt circle. The wheels are sometimes called "speed wheels" and have a bolt circle of around 12". I have some of those brake drums and wheels laying around.
The Ford spoke wheels have a tendency to break spokes. You should rap each spoke with a light hammer and listen to the tone. They should all sound the same.
If your are using a rear axle, you need to understand that the end of the axle shaft is tapered. The hub has to be pulled off the axle. You will see an annular notch where a special puller grabs the hub. Once tension is applied, a swift blow with a 2 pound hammer on the puller screw head will pop them off.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
