Re: Super m transmission
Posted by D Slater on December 01, 2006 at 10:08:43 from (152.163.100.65):
In Reply to: Super m transmission posted by Jacob E. on December 01, 2006 at 08:25:20:
Near end of M production the input shaft was changed along with bearing cage, front bearing,bearing retainer ,seal and drive coupler and same parts used in SM. If complete shaft and bearing cage bearings seals are used from pre change M it will work in SM and vice versa. Never tried shaft interchange without changing assembly so can't say for sure they won't interchange. Constant mesh gear is same as M. Think I have SM input shaft and constant mesh gear used in good condition reasonable if interested.
