Re: super h will run a little will then blow a co
Posted by Bob on December 02, 2006 at 11:14:22 from (69.178.229.154):
In Reply to: super h will run a little will then blow a conden posted by na na on December 02, 2006 at 10:50:35:
You've either fallen into a bunch of bad condensors, or there is something else wrong... poor connection or short in that distributor that is momentarily "repaired" when you wiggle things around to replace the condensor.
Have you ever tried putting one of the "bad" condensors back in, to see if it "works" again, for a while?
If, in fact, the condensors ARE failing, where have you been getting them?
Try a CNH, Blue Streak, or NAPA Premium condensor.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
