Re: 6v to 12v
Posted by gene bender on December 04, 2006 at 02:58:33 from (67.55.226.214):
In Reply to: 6v to 12v posted by Farmall H Newbie on December 03, 2006 at 22:17:06:
Of course you can. But if your starter and battery along with 1ga cables are in good shape you dont need to change. How do you think we used these tractors in1950 they started and worked just fine on the 6v system. You can find a small alternator that will fit under the hood then rewire it to the charging system change the lite bulbs get the rite size battery to fit in the box and away you go.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
