Re: 6v to 12v
Posted by El Toro on December 04, 2006 at 04:23:30 from (152.163.100.65):
In Reply to: 6v to 12v posted by Farmall H Newbie on December 03, 2006 at 22:17:06:
If you install a 12 volt alternator your coil wiring needs to be changed. Using a negative ground on the battery, the wire from the negative
terminal on the coil will now feed the distributor. Since your coil is 6 volts you will need to install a ballast resistor between the coil and the ignition switch or buy a 12 volt coil similar to NAPA's 1C14SB and no resistor is needed. Hal
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
