Re: 6v to 12v
Posted by John T on December 04, 2006 at 07:50:03 from (66.244.90.5):
In Reply to: 6v to 12v posted by Farmall H Newbie on December 03, 2006 at 22:17:06:
Sure it can be done and you can use a new or used or rebuilt 12 volt genny and 12 volt Voltage Regulator or have your 6 volt genny rebuilt to 12 volts or go the 12 volt alternator route if originality dont matter whatsoever to you buttttttttttttttttttttttttttttttt
Especially on an H which isnt all that hard to crank, whu not keep it original 6 volts??? If slow cranking is a problem try the biggest heaviest highest CCA and Amp/Hr 6 volt battery that will physically fit and use 00 gauge battery n Starter n ground cables and if shes kept in tune and the engine is in any kind of condition at all she ought to start just fine even at cold temps. If she dont despite the things I mentioned, Id fix the problem before I butchered up the tractor if it were mine, but its your tractor and your choice so if you wanna convert it and need more detailed instructions post back n let us know.
best wishes
John T
Today's Featured Article - A Belt Pulley? Really Doing Something? - by Chris Pratt. Belt Pulleys! Most of us conjure up a picture of a massive thresher with a wide belt lazily arching to a tractor 35 feet away throwing a cloud of dust, straw and grain, and while nostalgic, not too practical a method of using our tractors. While this may have been the bread and butter of the belt work in the past (since this is what made the money on many farms), the smaller tasks may have been and still can be its real claim to fame. The thresher would bring in the harvest (and income) once a y ... [Read Article]
