Radiator Drain
Posted by b2187101 on December 04, 2006 at 10:59:00 from (64.246.114.214):
Now that I know I should have a fresh mix of 50-50 in the
radiator for this winter...how do you drain it? Is this procedure
in the operators manual? Rough estimate of how much fluid is
in an H radiator?
