Re: 756 overhaul
Posted by Marv on December 04, 2006 at 14:40:45 from (71.7.39.212):
In Reply to: 756 overhaul posted by Alex in Texas on December 04, 2006 at 13:01:55:
I have two 756 D310's I have overhauled. The first one had 9000 hours on it when I noticed antifreeze in the oil. I replaced the sleeve O rings as well as the sleeves and pistons. That was 1000 hours ago and it is still running great. This was an inframe overhaul.The second one was a tractor I bought. The previous owner took the head off and allowed water to get in the engine. I had this engine bead blasted because of the rust. On this engine the cam was removed because of the rust. To replace the cam, the engine had to be linebored which cost about $200 but worth every penny. I put new sleeves and pistons in also. The heads on both engines were OK. I did replace some exhaust valves. Marv
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
