Re: 756 overhaul
Posted by Josh in Pa on December 04, 2006 at 15:15:47 from (72.165.152.4):
In Reply to: 756 overhaul posted by Alex in Texas on December 04, 2006 at 13:01:55:
I'm doing the same on an Oliver. Started with an in-frame and progressed to a total rebuild. I think if the engine is out, I would take it in and have it cleaned and magnafluxed. Clean will make it nice to put back together, and you won't get it back together and find that the block is cracked.
Josh
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
