Re: Hi Hugh MacKay
Posted by Fromjb2 on December 04, 2006 at 17:09:50 from (74.101.67.211):
In Reply to: Hi Hugh MacKay posted by MJ in the UK on December 04, 2006 at 09:42:26:
Hugh, I agree with you pulling ability is all about HP to weight ratio. My uncle had a JD M about 20 HP similar to IH SA. The rear tires were calcium filled and a set of wheel weights. In the fall when we were hauling corn silage wagons (IH silage wagons) from the field to the silo that JD M would out pull the MF 35 and 135 that the neighbours had. The MFs also had calcium in the rears but had to much HP (35) for the weight on the rear and would spin out.
Just like a corvette on an icy road.
JB2
