Re: Mounting a JD 45 loader on a Farmall 400.
Posted by Rustyfarmall on December 05, 2006 at 10:30:19 from (207.32.13.206):
In Reply to: Re: Mounting a JD 45 loader on a Farmall 400. posted by Farmer Jack on December 05, 2006 at 09:35:06:
The Farmall Hs and Ms were the same length, and equally share mounted implements, including loaders. The 300 through 450 tractors were longer due to the TA, but once again were designed to equally share mounted implements, so if you have the adapter bracket for the 350, it will also work on your 450.
