Re: Hydra u lic Fluid :-)
Posted by Rustyfarmall on December 05, 2006 at 13:46:19 from (216.248.75.183):
In Reply to: Hydra u lic Fluid :-) posted by Tom Windsor on December 05, 2006 at 13:13:46:
Original specs called for non-detergent 30, 20, or 10 wt., depending on if you are using it in warm weather, cooler weather, or really cold. The belly pump will hold about 6 qts., but you may need more than 6 qts depending on the implement you are using. If there is not enough oil, the implement will not raise to the top. If you have too much oil, the excess will squirt out the vent hole in the fill cap. Other than making a mess, no harm will be done.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
