Re: What is a Cub lowboy worth? I beleive it to be a 1976 m
Posted by screwstick on April 12, 2009 at 06:26:31 from (75.89.28.9):
In Reply to: What is a Cub lowboy worth? I beleive it to be a 1976 mo... posted by Nicholaus Sowder on April 11, 2009 at 21:02:06:
If it is in fact a '76 model, you are looking at a numbered series lowboy, which is slightly different than the older, offset lowboys. The numbered series has an inline driveline, a more complex clutch setup with a higher HP engine and everything is mounted in a frame. The PTO is independent which is an inprovement over the older models.
Either way, old style lowboy or numbered lowboy, $1400 is not bad if everything is in good shape. Good Luck.
