Re: Farmall B Engine Replacement.
Posted by Hugh MacKay on December 06, 2006 at 02:34:12 from (216.208.58.126):
In Reply to: Farmall B Engine Replacement. posted by billde on December 05, 2006 at 15:36:11:
Bill: Any engine from an A, B, SA, SA1, 100, 130, 140, C, SC, 200, 230 and 240 will bolt up. Mike is right, not many SA had water pump from factory, however a good many have it today. You can use a water pump on your B, finding a thermostat and top couplings from engine to rad, will be a bit of a chalange, but not impossible. There are folks running them without thermostats.
Another item that might require changing is water pump and fan assembly from a 140 or 240. They both have fan hub, automotive type water pump. I know the fan and shroud arrangment is a bit different on my 140 from the 130. I don't know that it is enough different, that it wont match up.
Number 3, don't expect to install a C-123 engine and have C-123 performance without changing breather. Air intake on C-123 is almost twice the size of C-113, I'm talking actual air stack.
