Re: super a runs rotten
Posted by K-Mo on December 06, 2006 at 05:39:11 from (65.169.189.2):
In Reply to: super a runs rotten posted by rch on December 06, 2006 at 05:16:12:
Assuming everything you have mentioned is good (fuel & fire), my first guess would be sticky valves. Although I don't believe in additives, I will used them as a last resort before tearing an engine down. Maybe someone has a recommended additive you could try.
K-Mo
