Re: Which Binder Manual is correct one for plow?
Posted by Nat 2 on December 07, 2006 at 05:02:22 from (64.80.108.53):
In Reply to: Re: Which Binder Manual is correct one for plow? posted by CenTex Farmall on December 06, 2006 at 20:19:42:
I sincerely doubt if there is anything special about that tire, except maybe for the wear pattern.
Someone mistakenly called the tail wheel the "furrow wheel" the other day. The furrow wheel is on the right front of the plow. Which one are you talking about? If the tail wheel, the reason it's sloped is because of normal wear.
