Re: M popping out of 5th
Posted by Randy S.E.-MN on December 07, 2006 at 05:13:13 from (206.9.216.56):
In Reply to: M popping out of 5th posted by City-Boy McCoy on December 07, 2006 at 04:57:40:
Yes it could be a major problem... either the shift fork is bent, or in the case of fifth gear, the little nubbins they call teeth which comprise fifth gear are worn sufficiently away. (usually from trying to speedshift into fifth gear, and grinding the teeth away). I believe either way, the cover has to come off and trans input shaft must be removed,and-or replaced.
