Re: The H is home
Posted by banjo on December 07, 2006 at 10:04:15 from (65.67.203.125):
In Reply to: Re: The H is home posted by CNKS on December 07, 2006 at 09:19:24:
The steering post has been replaced with a peice of galvanized pipe, are the control arm and acuating rod hard to find? Like i said i need manuals. I am used to the super a,cub as far as controls are concerned.
I did get the hand crank loose and moved the pistons (not far)so it is not stuck. May put some oil in cylinders just as a precaution. Going to be a while before i even start it or try to start it.Lots of dirt daubber nests to clean out..
