Re: Pullin' the pilot bearing
Posted by banjo on December 07, 2006 at 16:13:04 from (65.67.203.50):
In Reply to: Pullin' the pilot bearing posted by Dennis Gauge on December 07, 2006 at 14:06:03:
I've never had a problem with the ole socket and grease trick. sometimes i needed a bigger hammer but it has always worked for me so far.
