Re: M popping out of 5th
Posted by Haas on December 07, 2006 at 18:23:34 from (12.65.12.52):
In Reply to: M popping out of 5th posted by City-Boy McCoy on December 07, 2006 at 04:57:40:
Most likely the 4/5th slider gear is worn out, meaning the inside teeth that engage the driving gear are about gone. Being able to hold it in gear with the shifter is another symtom of this situation. It will eventually get to where you can't hold it in if there is any load to speak of though. Also a worn pilot bearing will add to the problem.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
