Re: Farmall H, SH, M, SM, 300, 350, 400 450 gover
Posted by D Slater on December 08, 2006 at 07:33:19 from (152.163.100.65):
In Reply to: Farmall H, SH, M, SM, 300, 350, 400 450 governor posted by jhb on December 08, 2006 at 05:30:12:
Lower housings and internall parts are the same except some changes IH made along the way and the throttle rod length up to the shaft that goes to carburator. H,SH,300 and 350 have a shorter housing on top of governor for throttle shaft than M through 450 do. H, SH,300 and 350 have a shorter throttle tube and shaft to carburator tha M to 450 with H being little longer than SH ,300 an 350. Some real early throttle tubes were different and latter ones use a seal for shaft compared to most mid production tractors. H SH M SM SMTA use a different shape control shaft that hand throttle linkage hooks to than what 300 through 450 use. Governor drive gears are different from H through 350 compared to M through 450 but shaft is the same that gears go on. I probably missed something.
