Re: 400 live pump, fit an H ?
Posted by Nat 2 on December 10, 2006 at 08:05:45 from (69.204.107.149):
In Reply to: Re: 400 live pump, fit an H ? posted by Randy as in Randy-IA on December 09, 2006 at 18:41:56:
Sometime in 1950, IH changed the front cover and timing gears on the Ms, so a factory live pump will work. Ms older than 1950 need to have the newer front cover and timing gear set installed.
