Re: 300U front wheel bearing torque?
Posted by Fromjb2 on December 10, 2006 at 12:08:06 from (74.101.67.211):
In Reply to: 300U front wheel bearing torque? posted by JayWalt on December 10, 2006 at 10:41:25:
Hi Jay, in the I&T shop manual for IH 684 front wheel bearings that are tapered roller bearings, it says: Tighten nut to 70 ft-lbs while rotating wheel, back nut off, then re torque to 50 ft-lbs., back nut off 1/4 turn and install cotter key.
Hope this helps
JB2
