Re: Super M loader hydaulics
Posted by Tallperson on December 10, 2006 at 12:14:28 from (165.170.128.66):
In Reply to: Super M loader hydaulics posted by Tallperson on December 05, 2006 at 20:19:09:
Thanks for the response guys. These are all things that I will look at. The loader is run from a 2 control section . Up,down and neutral for the bucket and up, down neutral and float for the loader arms. I will get a pressure gauge and install. I will also check into rebuilding the loader controls to eliminate the control valve bleed by problem. I will check these issues out and either up date or send up a flare for more help.. Tallperson
p.s. Merry Christmas to all and a happy New Year.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
