Re: W-9 PTO
Posted by D Slater on December 10, 2006 at 16:06:16 from (64.12.116.65):
In Reply to: Re: W-9 PTO posted by jhauck on December 10, 2006 at 15:25:51:
If theres trouble with the shift lever and related parts you should be able to see the problem when PTO is removed. If so you can use M parts if needed. If it quits driving when load is put on PTO the splines on shifter sleeve or counter shaft may be worn, or a problem with spring and popet for internal shift lever. If there's a problem engaging PTO the PTO shaft at front or bushing in counter shaft may be worn.
