Re: Shimmy/wobble front wheels
Posted by Nat 2 on December 11, 2006 at 05:08:45 from (64.80.108.52):
In Reply to: Shimmy/wobble front wheels posted by Tom Windsor on December 10, 2006 at 15:09:34:
Sorry Tom, no quick fix. The tire pressure trick only partially helps, and doesn't cure the problem.
What you've most likely got is several small slops combining to create one huge honkin' slop. The teeth are likely somewhat worn, creating a little slop. The splines on top of the vertical shaft are somewhat worn, creating a little more slop. The bushings holding the vertical shaft are also somewhat worn, creating a little more slop.
