Re: H Service Question
Posted by Don L C on December 11, 2006 at 07:24:57 from (71.79.19.153):
In Reply to: H Service Question posted by James Newton on December 10, 2006 at 18:44:03:
Add as much heating oil as it will hold, that will thin out the old lube, run it around to mix and wash the gears and housing.....drain and put about 5 gallon heating oil in, drive it around ( no load) then drain......should be clean......add new gear oil........Don
