Re: How much fuel
Posted by CNKS on December 11, 2006 at 09:17:50 from (204.249.178.135):
In Reply to: Re: How much fuel posted by Steven@AZ on December 11, 2006 at 07:51:16:
I don't farm, therefore due to the limited use I put enough gas in to run an hour or so, and also make sure there is enough in the tank to prevent problems during storage. Actually mine are stored most of the time, some may only get started a couple of times a year. Those I add a couple of gallons of fresh gas to and start them -- again, I have had no problems. I do not believe you need to keep the tanks full during the winter or summer, gas stabilizer is not needed either. I have an H that probably has residual gas that's 5 years old -- I only put a little gas in it so that it will start to make sure that it runs, will rebuild it someday. Only my opinion, this is one of those repeated questions I should not respond to, basically you can shut off the engine and walk away -- it will start the next spring.
