Injection pump troubles
Posted by Erik in WI on December 11, 2006 at 12:51:51 from (65.162.45.30):
My 1466's injection pump is stuck at wide open. I would like to move the tractor into the shop, so the pump can be removed and rebuilt, so.....
Is there any way I can 'trick' the pump to stay at idle while I move the tractor? I hate to let it sit outside with no pump on it, but I hate to start the tractor and have it go screaming to 2600 rpm on a cold motor.
Thanks in advance for any help
Erik in WI
