Re: Manifold heat control valve
Posted by CNKS on December 11, 2006 at 20:13:17 from (204.249.178.135):
In Reply to: Re: Manifold heat control valve posted by jakee on December 11, 2006 at 18:47:00:
I don't understand why it needs much tension. The more tension, the hotter it has to be before the spring expands enough so that the weight can close the valve. It only needs to be open until the tractor warms up. You don't want it open long, because once it is at operating temperature the tractor runs best on a cooler fuel-air mixture. What problems were you having? Seems they should be worse with it stuck open than closed. On this engine closed means that most of the exhaust is blocked from the mixture. If what you say is correct, I'm missing something or else we have different valves?
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
